It takes a tremendous amount of experience to do a stone job well, and it uses a lot of stone to do it properly and this is not meant as a personal cut on whoever uses them. That's actually how I learned to do valve jobs. That was in the 80s. Time and technology marches on and a tapered pilot will never be as good in terms of concentricity, accuracy, or repeatability as a properly sized straight pilot, floating head, and multiple angle cutter. In my garage here is a Petersen TCM-25. Again, old school in terms of valve/seat equipment (It's also from the 80s), but it will do way better than a set of tapered pilots and the most careful stone grinder. I'm not saying they won't run with a stone valve job or that anyone personally sucks at it. I'm saying that comparing results to results, even if the stone setup is done as perfectly as it can get, there is MUCH better, for similar money, no way to get them as good as the modern Serdi or Sunnen equipment. The shop I use has the Serdi. My TCM is for sale.
I'll add for years I ran dial up, because of my home location (waaaay in the sticks). I'm not spoiled. I'm a realist with high expectations...lol
