I suppose it could be a starter relay, but I doubt it. The spade orientation doesn't look right. Nor does it look right for a horn relay.So.....IDK........ either
Here's a few more pictures of the location of.
I'm thankful for your help with.. Hope this is more helpful to anyone as seeing the full placement of the starter relay as to the left of the harness connection point.. the part I need to replace is to the right of.. in the empty spot above the master cylinder
It actually doesn't
Factory one
Never has since I owned the car..
I only got concerned about the relay when I saw the broken off connector..
Didn't dare even turn the key
Whereas protect and respect..
Thank you so much..
And everyone who has helped!
Such a great relief for me.. I was thinking it may have been a voltage regulator reducing of some sort.. thanks!!
