i have a 65 valiant/baracuda clone i'm in process of a disk brake conversion i need 14" rally wheels (2) that will fit disk brakes price and location plz. thanks
just the 73 stock conversionWhat disk brake conversion did you use, some conversions will not hold a 14'' wheel.
Are you going BBP (Big Bold Pattern) 5 on 4 1/2 ?
I am not sure what year my 14'' front wheels are from but they fit my 73 up single piston mopar disc brakes, I wonder if the year model wheel is what is hanging up on your front end, my 14'' work fine on my Ram Man disc brakesjust the 73 stock conversion
A pair of 14 X 5.5 BBC here...... cheap!
PM me.View attachment 1714929289
i don't know this is my first "mopar" adventure.. have a 1971 buick gs so new territory.. i got the rotors new which were given to me plus the spindles and caliper slide in brackets.. when got the car was told that i needed to swap out the front wheels for the bigger bolt pattern to clear the rotor hole hub size and clear the calipers.I am not sure what year my 14'' front wheels are from but they fit my 73 up single piston mopar disc brakes, I wonder if the year model wheel is what is hanging up on your front end, my 14'' work fine on my Ram Man disc brakes
