[WANTED] Need 1968 Barracuda Right Rear Lower Quarter
blk340cuda
Active Member
Michigan
Rating - 0%
0   0   0
Need a lower right rear quarter patch for a 1968 barracuda. Also looking for a 8 3/4 housing for "A" body and A833 Trans.
I have a bell housing and I think a 4 speed tranny. Located in West Branch. I think 3ird gear needs work. I have a lot of 67-69 barracuda parts. But no axle housings. Do you need a bell housing?
Well let me know if you have the trans and maybe I'll do the package. Do you have any interior parts? I need a deluxe bucket and dash parts....
I may have a lower patch from a 67 that would work.
How far up are looking to patch in?
Hi, I found that 4 speed and the bell housing along with the pressure plate and clutch if your interested make me an offer.
Lower patch would be perfect if 2 inches below marker light hole flat across to wheel well.
What condition is the trans? Does it need gears? What type of pressure plate? Do you have any pictures? What year and gear ratio's.....
4spd bellhousing
