The trans on the left is an A230 3 speed. Duster transmission. Nuthin special. Trans on the right, A833 OD. Notice anything funny? Yup, you guessed it. The 5.125" front bearing retainer that came on the OD trans is bolted to the A230. The 4.180" front bearing retainer that came on the A230 3 speed is bolted on the A833 OD. There is also a large bolt pattern 4.350" bearing retainer that fits the OD and the A230 that will correctly adapt the 4.350" hole bellhousing. I had one, but I gave it away to a friend so that he could bolt his 4.350" hole bellhousing to his A833 4 speed OD without having to pay stupid money for the "special" bellhousing. Pic number two is a standard 4.80" hole small block bellhousing. Nuthin special about it. They made a bajillion of them. There is NO need whatsoever to make stupid spacer rings or turn down an otherwise perfectly good retainer when the correct parts are available to do it RIGHT. I have done these swaps probably 20 or 30 times in the past. They worked fine each time.
