alsdemon
next door neibor has a 92 150 2wheel 318 inj. has a stumble when cold or under slite load highway in o/drive. has new coil went bad would not start till new coil was installed. now has a stumble when taking off or highway speed low rpms.find after more gas is given. fuel presser check find.new cap rotor and plugs. will a dist. from 98 dak. 318 work in this or needs to be closer in years. no check engine light on. he said it,s getting worse day by day it,s his work truck and is driven daily 30 miles or more daily. thanks for the help.
