Need a Picture....
roughidle
Super Platinum Member
Pennsylvania
Does anyone have a picture already or could take a picture of the rear floor pan in a '68 Barracuda. What I need to see are the locations of the seat belt mount locations for the rear seats. The center two are there, but I believe somewhere along the way during the mini tubbing I've lost the outer points. I might think any '67-'69 Barracuda Valiant Dart should suffice....
Thanks in advance....
D
I did a mini tub in my 69 Dart, I'll take a pic when i get home today if someone hasn't helped you already.
Not the best quality pics...........but here you go.
Thanks... Does anyone know for sure whether the notchback/fastback locations are the same? Looks like it would've definately been lost in the minitub....
Probably depends on how you did yours. Here's mine, you can see where it was just barely saved next to where the tub was re-welded
Did you get what you needed in pics. I have a 69 FB cuda with the rear wheels off and I noticed that the seat belt bolt mounts under the car are right there outside of the frame. I can take a pic if you like. They are both very nicely exposed at the moment.
Treblig
If you'd get a chance that would be great. The more views the better!
Thanks
My 69 FB just before paint. Outside mount on either side of the frame rails from underneath.
Here you go.The pics that show the measuring tape, I had the tape either pushed up against the outside of the big curl in the front of the leaf spring or against the frame rail depending on which pic you're looking at. You can also see the factory spring clip that holds brake line.Looks like the belt bolt plate is installed right up against the frame rail.
Treblig
