AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,079
- Reaction score
- 12,422
And that is why I pulled the MOPAR 292/292/508 cam outta my engine.
It looked good in the calculator at 11.3 Scr, But the low-rpm pull was just not there with my starter gear of 2.66x3.55=9.44.
Here's what I thought I was getting,@900ft
1) Static compression ratio of 11.3:1.
in at 104, for an ICA of 70* using advertised
Effective stroke is 2.64 inches.
Your dynamic compression ratio is 8.60:1 .
Your dynamic cranking pressure is 174.84 PSI.
V/P (Volume to Pressure Index) is 142VP ................................................... 142VP
For aluminum heads that looks reasonable. With a clutch, I can work with that meager 142VP.
But .008 tappet lift, with my 1.6 arms is about .0128 valve lift. So we got a long way to go, before that intake seals up. Say it takes 8* to get there, And this is what the Wallace spits out;
2) Static compression ratio of 11.3:1.
True ICA is 78*
Effective stroke is 2.42 inches.
Your dynamic compression ratio is 7.96:1 .
Your dynamic cranking pressure is 157.68 PSI.
V/P (Volume to Pressure Index) is 117VP...................................................... 117
Well that Sux
Now,my actual measured pressure was not that low, So let's assume there was for a moment that 8* was too much compensation. Lets try it at 6*, and advance the cam to 100, and that would get us an ICA of 72* valve fully seated.
3) Static compression ratio of 11.3:1.
True ICA is 72*
Effective stroke is 2.58 inches.
Your dynamic compression ratio is 8.42:1 .
Your dynamic cranking pressure is 169.98 PSI.
V/P (Volume to Pressure Index) is 135VP .................................................. 135
Still soggy, almost a waste of aluminum heads, inas-much as I ran this with 87E10. I mightabin able to run iron and 91 with a gasket swap, and saved a ton of money..
So I pulled that cam and sold ASAP.Actually I sold it first, then pulled it
So then I got me a Hughes HE2430AL, with specs of 223/230/110 I figured that's a long way from the 248* of the previous cam. I still didn't know why that 292 had been so soggy, I just knew, I didn't want anything more to do with it.At the time (year 2000 or 2001) Hughes did not publish the advertised on this 223 cam. Now they call it a 270/276/[email protected] lift..... but they don't say .008 tappet or .008 valve. So, to be consistent, Lets go with tappet, and that gets me the same .0128 valve lift with 1.6 arms.
So this cam went in at 106, so the ICA was 61*, and the Wallace reads
4) Static compression ratio of 11.3:1.
ICA of 61*, using advertised
Effective stroke is 2.86 inches.
Your dynamic compression ratio is 9.23:1 .
Your dynamic cranking pressure is 191.98 PSI.
V/P (Volume to Pressure Index) is 169VP ............................................ 169
Which looks real nice on paper, but being a newbe,I deemed the pressure too much, and swapped in a different gasket, and changed the pushrods. And then on paper I got;
5) Static compression ratio of 10.9:1.
ICA still 61*still advertised
Your dynamic compression ratio is 8.91:1 .
Your dynamic cranking pressure is 183.24 PSI.
V/P (Volume to Pressure Index) is 161VP ........................................... 161
So I slammed it together, and this combo flew. It was just what I wanted.Oddly enough 185psi is what I measured.
And I drove it that way for 4 years until the lobes began to fall off.
But now this intake duration is also not with the valve closed. Hughes calls it a fast-rate, but very likely this does not include the clearance ramps, so to compare this cam to the Mopar, lets add 6* to get the intake valve sealed,as before. And I get a TRUE ICA of 67*
Aaaaaand Mr. Wallace says;
6) Static compression ratio of 10.9:1.
Now;True ICA of 67*
Effective stroke is 2.72 inches.
Your dynamic compression ratio is 8.52:1 .
Your dynamic cranking pressure is 172.68 PSI.
V/P (Volume to Pressure Index) is 145VP .............................................. 145
Well That's a little disappointing......... on paper.... Nevertheless this combo made huge torque.That combo was awesome at the line!!
So now to be fair to the Mopar, lets compare #6 here with #3 above...... Hah only 3 psi more here, yet the VP is 7.4% higher.
Who knew 7.4% could make such a HUGE difference?!
Well, that is akin to swapping rear gears from 3.55s to 3.81s
The 6*and 8* degrees of compensation above , I plucked from a hat. I have no idea what the real world numbers might be.
By the next cam,I already had the GVOD, so I gave up and just put in 4.30s. Maybe I shouldda done that with the Mopar, but..... nobody said I was the sharpest knife in the drawer.
I gotta hand it to the Mopar tho, once the engine hit 5000, it just zinged to the top, 7000/7200 was BAM!!!
True ICA is 78*
Well that Sux
True ICA is 72*
Now;True ICA of 67*
