Need a sure answer ASAP
318willrun
Utube channel 318willrun
I'm here
'77 Ramcharger wiper motor - no parts stores seem to sell them. Ebay list the Cardone 40-380 to fit the '77 dodge truck, but not the Ramcharger????? Same with the parts stores, they can get the Cardone 40-380, but say it won't fit the ramcharger (but will fit a '77 dodge truck?)
thanks
It is crazy because if you get the right one it will fit. But I found that between years they changed them for some stupid reason. I have had basically identical vehicles not be the same. Bolt pattern and wiring being the big issues. I think..not sure but I think I have a couple laying around. Get me a picture and I will see if I can hook you up.
I've ordered it (the same part number as the ebay one) through O'reillys. Bolt pattern and wire plug looks the same. I'll see in a day, and post if it works.
Thanks a lot :)
I HAVE interchanged between pickups and ramchargers. You just have to get the right one.
It worked :)
a little noisier, but it works
