BigStrok3
Mopar!
Im looking into buying a sand blaster to strip the paint off my engine compartment after taking everything out. I would rather do this because ive heard it is much easier than using sand paper. Just wanting to know what grit I should use for the job and what kind of material to blast with? Also if you think that this blaster would be good for the job? or if you have any tips or pointers if you have blasted your engine compartment before. Thanks in advance!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34202
