pagilman
:angry7:I was putting rocker shafts on a 340 and broke off the center pedistal bolt at 30lbs of torque. It broke off flush at the top of the threads and will be hard to work on. I plan on starting small and working up with the drill bits untill I can get an easyout in it, if they make one that small. Has this ever happened to any of you and how did you repair it, i don't want to remove the (iron) head and take it to a shop. thanks for any advise, Walt:angry7:
