Hi all, I'm doing the front drums on my 72 Scamp, SBP. I got the drums pulled and ordered the new ones (along with many other items). The new drums appear to come without the wheel stud and the hub. Is the factory hub pressed or brazed in? I cannot figure it out. These pics are of what is on the car, and what O'Reilly had. The raising of the center area is different than what is on the car. Not sure these will even work so I did not buy them. Has anyone ran into this problem before? The drums cannot be turned so I'm not sure what the next step.
Note: I do NOT plan on doing disc brakes if I can help it. I will do discs when I convert to BBP which is not in the near future. Only will do discs if nothing else will work. Thanks for your all's help!
