need cam specs
elkhart
picked up a edelbrock torker plus cam kit #5077 on the box. any info would help could not find this anywhere online good cam ? bad cam? thanks
I found this for you.
CAMSHAFT: Torker-Plus Hydraulic CATALOG #5077
ENGINE: Chrysler 340-360 c.i.d. V8
RPM RANGE: 2500-6500
CAUTION:
Do not use dual valve springs.
Use only recommended Edelbrock Sure Seat Valve Springs #5777.
Use stock ratio rocker arms only
Duration at .006" Lift:
Intake 306 ̊
Exhaust 316 ̊
Duration at .050" Lift:
Intake 222 ̊
Exhaust 232 ̊
Lift at cam:
Intake .298"
Exhaust .300"
Lift at valve:
Intake .447"
Exhaust .450"
Timing at .050 Lift:
Open
Close
Intake
4 ̊ BTDC
38 ̊ ABDC
Exhaust
53 ̊ BBDC
1 ̊ BTDC
Intake Centerline: 107 ̊
Lobe Separation: 112°
• CAUTION:
Use Edelbrock Performer-Link Timing Chain Set #7803. Do not use late model timing chain and gear sets that are designed for emission-controlled engines. These timing sets are machined in a retarded position and are not recommended for this camshaft installation. Edelbrock
Timing Sets feature three keyways for specified timing selection.
link for info:
[ame]http://www.performancedepot.com/ART/products/100626/5077_Inst.pdf[/ame]
