NEED female neutral safety switch
HevD
Cloquet, MN
Hello,
Does anyone here know where I might be able to find the FEMALE end of the neutral safety switch? I am able to find plenty of the MALE ends, but not the female side. It doesn't appear to be something the aftermarket makes.
Mine is beyond repair and I need to replace it, so if anyone has the FEMALE end laying around, I'd be happy to buy it from you.
Thanks!
HevD
The female end is the connector to the trans right?
I made my own connections by cutting the plug end off and by making use of cylinder electrical connectors to shove on the pin ends of the in trans switch. I just had to crush the ends down a tiny tad for a tight fit.
Radio Shack has these connectors.
