need/have to go 13.50's in 1/4
He might need the sag from his old springs to keep that four speed under control off the line!!! Unless he's really good at finesse and has launched it more than a few times!! Also agree with drag radials and a bigger carb!! You should be able to get it done without a problem!! Run a little less than standard pressure in the rear tires and pump the fronts up some, that should help some also!!
Do anything you can to trim time from your combo without spending money... Indexing plugs and other old school tricks don't hurt and can only add to your combo already!! JMO of course!! Geof
