solid or hyd great lit YR (and look who's missing- there is a reason)
There are more modern grinds than the purple shafts
I do not think Jones has any non racy solids but fill out his form anyway you get best suggestion
he has the best 256-260 hyd but maybe too short for your compression
AJ what do you think?
Street Performance | Jones Cams find approx flows for your heads, there is another thread on this currently, and exhaust???
Engle has both solid and Hyd as does Bullet good range of Mopar grinds including a line of street lobes (and race lobes)
Lunati if you want a catalog grind but as opposed to jones it's luck of the draw with tech support (same with some of the others)
you can PM Dart19666 at Crower- he gives good guy prices but BVVC that you are getting a MOPAR grind as some of their short catalog grinds are chevies
bit then so are the short catalog Engles and most other camgrinders.
Lunati Voodoos are all MOPAR- they call their budget chevy lobe line something else- which I like
Bullet has full line but YOU have to ask for a Mopar special
Racer Brown needs no introduction
figure out how you want to drive it
daily driver, gas mileage important, or cruiz to the drive in, or open road, etc
what did you figure your compression was? *** is *** will be
