cobrabike
Active Member
I am about to start the rebuild of my 8 3/4 for my Valiant. I am going to need new axles since I cut a b body rearend down to a body size. I tried to locate some truck axles to cut down, which has failed misserably.
So, who has the best price on a good set of axles that will take the taper roller bearing. I will use the b body brakes with the lbp. This will be a decent street car with a mild 360. I do expect to make a few passes at the dragstrip; however. the car will be used mostly for cruising.
Thanks
Thanks
