Bmsjax
I am looking to replace my stock axle from my '70 duster. But I dont know what I can and cannot use. For example on Craigslist I see a 8 1/4" axle outta a '91 Jeep with a width of 61.5 inches. Would this work?
The F/M/J body 8¼ has an acceptable width. The spring perches are ½" too wide on each side.
The 64-66 Mustang/Falcon axle is a perfect fit. Watch out, a bunch of them used 4 bolt wheels.
The Ford Grenada/Mercury Monarch (75-80) rear axles also fit without alteration of the spring perches. The gold standard of this bunch has to be the Lincoln Versailles (77-80). In addition to 4.5" bolt pattern & the correct spring perch spacing, it had disk brakes.
If someone bashes you for using a Ford rear, tell 'em to write the check (for a Mopar sourced rear axle) and you'll swap it out.
Your talkin about the 8.8? I see a few around here for a decent price and will probably go with one of them. True I would prefer to stick with Mopar parts, but a good part is a good part dont matter who made it.
