After installing an 18" electric fan, new stereo and speakers, and MSD ignition, my alternator was in need of an upgrade. I went with a 75 amp model and decided to bypass the ammeter for safety. I'm 99.9% certain that I followed the diagram provided by madelectric to a "T"(attached).
I ran a 10 gauge wire from the alternator to the starter relay with 14 gauge fusible link. I ran 2, 12 gauge wires with a single 16 gauge fusible link from the starter relay through a grommet in the firewall. One wire went to the black wire near the bulkhead that used to receive power from the alternator. I connected the other new wire to the black wire where it used to attach to the ammeter.
I've triple checked the wiring diagram and this SHOULD work. The problem is that I now have no power inside of the passenger compartment, no ignition, no lights, not even the dome light. The one thing that does have power is the stereo, which is connected directly to the starter relay positive post (I know this because it has a light that flashes when the faceplate is removed).
I'm all out of ideas at this point. Everything worked just fine before I began, except for the lack of amperage. I'm sure that I'm overlooking something simple... Does anyone have any ideas what could be causing this?
