southerneagle
OK I have a 1964 Dodge D100 it's a factory /6 with 3 speed on the tree.
I got it without an engine and plan on putting in a 8-18-65 273cid, I still have the 3 speed trans. and the bell housing has the multi bolt holes in it.
The flywheel I have does not mate up to the crank with the bellhousing bolted up, it's about a 1/4 inch away from the crankshaft. Come to find out the flywheel is for a 1978 dodge truck. Does anyone know which flywheel I need or do I need a different bellhousing? Thanks for any advise.
