Need help pulling valve body
mopar_1974
Mankato, MN
Hi, pulling the valve body on my 727 and ran into a problem. I got it out but it is still hanging by a rod (park?) i thought it was just supposed to come out but i keep wiggling it and nothing happens. it is an 86-87 tranny. Any ideas on how this comes out? thanks, Eric
look for where that rod connects to the valve body.. there should be a little clip holding it on..
haha, wow. quick resposes that time. no drive shaft, out of the car. ill try turning the shaft. anyways, thanks for your help guys, i'll try that and see what happens.
if you decide to pull the clip watch you don't lose it.. that thing is small and will fly...lol
let us know how you make out.
pull toward the front of the bell housing lightly it should just pop out. it sounds like you are hung up on the park paul. good luck
Look out for that little steel ball in the shifter rooster. Mine popped out and had to chase it down the driveway....
Good Luck!
