ozley_2000
Active Member
When I first got the car it on occasion would make a single click and not turn over. I have replaced the alternator, the voltage regulator, the battery, and the starter relay. Every time a part gets changed out it work well for a while then then the click happens. What I can tell you is that when the car is running and I put a meter on the batter and I get is 12.11v is this standard? The last bit if info I have is if I try to jump the car off the starter relay it wont even spark. I have a theory that there maybe a fuzeable link hiding somewhere. Thanks for the help Oz
