need help with front hubs
jrs3232
New Member
jacksonville
I have a 1974 duster with drum brakes on front with 5 0n 4 lug patten. what hubs will interchange with it? what i am wanting to do is change it to disc brakes and 5 on 4 1/2 lug patten thanks
Just hubs with Mopar factory disc brakes that will mount to your spindles doesn't exist. You will need an aftermarket set up if you don't change the spindles. You can also use a compete set up off a donor car. There are a ton of threads on it and what the parts come off of here on FABO.
