Need help with idler arm ID
19_Dart_68
PA
Part number cast into it looks like 3402844 N18077
It came off my dart, but the steering was changed to a fast ratio setup with a C body manual box, a Mid-70's B-body Pitman arm and this idler arm. Not sure if the center link was changed.
The new idler arm that was ordered(for 74 Dart) is crooked, compared to the straight one that came off.
As long as it fits (proper taper, sleeve), as long as the length is same, and it puts the center link parallel to the car "level" side to side, I'd try it.
My understanding is, that people were selling fast ratio pitman arms without selling a matching idler, so in those cases the pitman did not match the idler.
Actually both idler arms fit the 1974 Abodies. Casting number 3402844 is the factory original idler arm. Moog made two idler arms in the 1970's.The standard design which looks like the original Chrysler idler arm and a high performance idler arm which looks like your "crooked" idler arm, part number K7086. The Moog standard design arm was discontinued many years ago and the high performance one is still being produced.
As long as the streight line distance ( blue lines) are the same
AND
The mounting locations are in the same plane on the body end and the crosslink end
AND
The mounting holes and widths and tapers and stud lengths are the same.
there should not be a problem
But I think @townsend answered your question.
Yes, center to center looks good.The size of the ball joint stud looks bigger, but that may just be the pic. I have to check it tonight.
