I'll tell ya it's always something! I'm installing a Kevko M302 oil pan on 360 block with a windage tray. The Kevko pickup has a tab that I asumme is supposed to mount to the Main bolt? The problem is that the windage is in the way:
So that's ok (I think) I'll just remove the windage and cut a clearance hole it, well then I find out the mounting hole is way to small to fit over the ARP main stud!
Before I just cut off this stupid tab off the the pickup, does anyone have another idea?
