furyus2
O. K., I just replaced the water pump and hoses on my 440/tf 64 Sport Fury. When I parked it, I noticed it was up around 200*. Usually runs 180*. Popped the hood several days later, and the UPPER hose was collapsed. I know the bottom one will sometimes do that, never seen the top do it. Opened the lever cap and the upper hose popped back out. I forgot to look at the bottom hose before releasing the cap, so I don't know if it was doing it too. So, two questions.1, What caused this? and, 2, if part of the cure is to have a hose with a spring in it, Where do I get the spring? none of the hoses at Rock auto had a spring in it, or I would have bought that one. Thanks.
