Looking at a set of stainless steel roller rockers for my 360.Has anyone run them on there engine?Read on here that proform and prw was junk dont need no more junk!Lots of info on here.Thanks JIM
If you find some make sure they have bushing pressed in for the shafts to ride on. If they don't they will eat your shafts up and put metal particles in your engine
bought a set of PRW stainless ... seem pretty good to me, and the valve tip geometry seems pretty good with RHS heads. I noticed that OU812 used them on a few builds
I used a set of PRW stainless bushed 1.6 rockers in a 418 build for a buddy. Cam is a Bullet solid FT with 265 at .050 and .620 lift. Still running strong 3-1/2 yrs. later and believe me he beats on it hard. Just make sure you check them over real good for burr's and clean them real good.
BTW: most of the stuff I've seen white performance advertise is cheap off shore junk.
