AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,079
- Reaction score
- 12,423
AJ doesn't understand electricity if he thinks it sits and waits for a place to go!
Oh common, it makes it easy to understand.
Damn son, you need to get out more.that is the strangest (automotive) piece I have ever seen in my life!
yes I have been living a sheltered lifeDamn son, you need to get out more.
"phasing" Correct, mech adv will not move it/vac adv will. mech adv shifts the rotor more CW (advancing the timing) cuz it reaches the cap terminal quicker but the phasing is unaltered. vac adv shifts the magnet CCW so the tooth reaches it earlier (advancing the timing) cuz it fires earlier which also shifts rotor phasing CCW. I think some dists just have poor quality control especially on the lower tang to top rotor clocking relationship. dig out your light/drill that hole.The reluctor/ points/ other triggers the spark. THAT IS WHEN you are seeing the "light." Because the rotor moves WITH that trigger, it won't move phasing.
& "thru the hole" is the bottom line since checking with cap off, it fires when the the reluctor "just leaves" being dead on with the magnet give or take a c hair & there is some leeway there but it is a good first test when there is a missing problem to see if it might be rotor phasing issues. we're all good in the 'hood now.Best that i can see thru that hole(with the hood on) it's dead nuts.
The cap and rotor tell a slightly different story.
I ran the #1 piston up on compression stroke to tdc.0 degrees on the balancer. My rotor button is between #1 and # 8.Could this be my problem. Do I need to re-clock my oil pump
That was my thought too, Del, which is the reason to ask exactly when it did this. Since it only happens once, and when the ignition switch is first used, I am beginning to suspect this type of problem. Downsr may have given a good clue in his last post above.The other thing that "might" be......and there are various issues with this..........
is that the thing is "false" triggering for some reason..........either a problem electronically in the unit, or due to some EMI/ RFI problem
