how do you disconnect the steering coupler from a manual steering box, so i can take the steering column out? i have already removed the roll pin but i still can't slide it apart. what am i missing?
Of course spray WD40 or PB Blaster in the hole where the roll pin was and let it sit overnight. There are many small splines on the shaft so a little rust can lock it tight.
