Need Help
Coyote Jack
Member #55, I'm old
Baxters Corner N.B. Canad
I have a chance to buy a large quantity of parts but I need to know what fits and what doesn't. The donor car is a 73 Dart Sport and I have a 72 Demon. I was wondering if the rear bumper would fit mine. There is a Dana rear. I think it is a direct bolt in. The drive shaft is off of a big block 727 setup and I have a 360. Does the same shifter fit a small block 727 and a big block 727? I have asked about the interior parts and know about the different door panels but everything else should fit with a little massaging I think.
Jack
Just my two cents, But I think you are right the Dana is a direct bolt in. As for the driveshaft, check the input shaft spline count butif I'm not mistaken they are the same. I know that the driveshaft for an A833 and 727 are the same(At least for an E-Body). But if the spline count is the same on the input shaft it will fit because overall the Smallblock 727 and the Bigblock 727 dimensionally are the same, so the length would be right.
