danielb927
I was playing around with the thermoquad today, and discovered that flooring the gas, I can only get the secondaries about a quarter open. I had my dad sit in the car and floor it, i made sure the choke was kicked off (sorry if my terminology is bad. I'm talking about the knob/flathead screw on the driver's side that you screw in-out to adjust the idle speed, that rides up and down to activate the choke. I held that down so the mechanical secondaries would activate).
Anyways, is there something I can do to adjust how high off the floor my pedal starts? It only seems like i need another third or half an inch of travel, but if I just tighten up the cable then obviously the idle won't be right anymore.
