That Avatar I have is indeed a AFB modified. I grabed that picture from another board and quized the poster about it. It is his carb that he use's on his race car.
So enquired about it. Other than what you can see, he gave up no infomation to it. Incase you can not see what was done, the following info was given;
Custom fitted air horn.
Machine work to make it into a double pump. Squirted in the rear.
Custom adjustable metering rods and the rods themselfs are a custom machined item.
The custom rods are so designed as to make metering changes quick and easy on the car and running if need be.
I have figured out how to make the carb into a double pumper in 2 ways, but have not yet set the theroy into practice. I need a carb to try it on. I'll be giving it a wirl when it gets cold out. To many things infront of me now that needs my attention before I set into tooling around.
The adjustable rods are simple to copy. I never would have thought of it myself. SOMEBODY was THINKING when they did that.
The air horn I'm not going to try and copy. Currently, K&N makes a stub stack taht I have used with good results, but it works best under certain conditions and just throwing it on the carb is not it.
If you just trow it on, it's terrible. It needs room to breath and ethier more filter height or an extreme lid will allow the stub stack to work. Stock height type air filters seem to hamper any potentail of the stub stack.
Again, I started to explore this area, but have been curtailed in tooling around until other truly important things get taken care of.
I do beileve that next spring, I can shjow what I have done and how they perform. The "Mule car & motor" will be the '79/318 in my '74 Duster and more likely tested at English town N.J. come spring.
You can see the screw around Duster project here;
http://www.forabodiesonly.com/mopar/showthread.php?t=10508
