You can get the power steering gearbox from any A-body for sure, but the pitman arm may have to be changed for your particular car. You will also need a power steering column, either column shift or floor shift, depending on what set-up you have. Also needed would be the power steering pump and brackets for your particular engine. Post your location and set-up and we'll see what comes up. I know for a fact that I have the gearbox from a 69 Dart, the pump and brackets from a smallblock, and a steering column from a column shifted 71 Dart. The swap is pretty easy, access to the gearbox being the limiting factor. P.M. me if you are interested in this stuff and we'll go from there, Geof
