It might have no effect on the idle circuit, but yes it should go richer in the upper rpms.BUT, if I were to close off one of the 3 emulsion holes, what would that do? I assume it would put less air in the fuel and it would run richer? Am I even close.
It may also delay the start of the mains, creating a lean transition.
The air bleeding into the main well lowers the overall density of the fluid mixture. So sometimes enlarging the main bleed brings in more fuel earlier - which shows up as richer AFR.
Going from very small or no bleeds to ideal size bleeds will do the same.
That's what this fig 11-11 from Obert shows.
Yellow highlights the start up with too little or no e-holes, and then that would also mean the main air bleed can't compensate for increasing draw at highest flows.
Emulsion Tuning
This probably causing more headaches than you realize.I may leave the emulsion alone until I have done more testing.
Fuel mix should be steady throughout the full load, wide open throttle. In other words, 3 (or 4th gear) pedal to the metal.Also went from #76 to #78 jets in the rear to fatten up the WOT. Last test with the #76 ( stock jet) AFR went to 13:1 at 5000 rpm.
Smaller carb will help fuel distribution. Larger carb has potential for higher top speed (more hp) at the 1/4 mile, and a fraction off the e.t. if fuel distribution is good.I am wondering since I am having to fatten up the carb, if I should have went to a 750 cfm. Power wise, I am right in that gray area (411 hp at 5700 rpm) where 650 cfm runs out and 750 cfm picks up.
See above comments.Put the #70 jets back in ( surging went away) the primary’s and at 3000 rpm in high gear I am around 12.5 ratio. It did not like the #68 jet in the primary’s.
I also went from #76 to #78 jet in the rear and the AFR is now at 12.8 ish at 5000 rpm. Should I leave it there or rejet the PVCR and fatten it up more. More jet? Engine makes full power at 5700 rpm.
Videos are now workingI am going to get some vacuum line this weekend so I can put the gauge in the car and check cruise vacuum.
