strange246
I'm installing my wiring harness, doing the connections at the column right now, stock column-Ron Francis Wiring kit, on the factory diagram there's 2 ignition wires, anyone know which is which? They're labeled "Ignition 1" and "Ignition 2"...I assume one would have power with key in start and run and the other in run and accessory...But the kit has just one wire that it says to connect to the Ignition terminal, which they say has power in run and crank ....There's also a Black heavy gauge wire labeled on the diagram "Accessory", what does that run to?
Ryan
Ryan
