Need Radiator with a temp sending unit
frederick_76
Milton, Wa.
Im looking for a Radiator for a 1969 Valiant 360cid 4 speed with a "Boss" fitting for the temp sending unit for an electric fan. I looked over my stocker and there is just no place to have one fitted. Any ideas?? Thanks, Dennis.
Buy a radiator with one on it.
Why not use this: then you don't need a hole in the raditor, I used this for years works fine, the sensor goes between the upper raditor tube and the hose, and the hose clamp keeps it in place
Times 2 on this response ^^^^^^^^^^^^^^^^^^ worked great for me and my 383 Fury years ago.
A radiator shop could drill a hole in the radiator and solder on a boss with a threaded hole for a sensor. But, I prefer 412 stroker's suggestion.
