... One of the distributor cap clips is broken off and it’s apparently being held together with a zip tie…thus causing it to misfire. So just going to replace the spark plugs since now having to replace the distributor...
You can just get that cap clip, they just slide in. Can you take a picture? Does the car still run points?
