Need some help please! Blinker wiring
/72Scamp
Hampton NH
Hey guys. Any help would be greatly appreciated. So in my 69 valiant the brake lights work great. And my right blinker works great in front a rear. My drivers side blinker when in the on position lights up the drivers side brake light which stays on solid and so does the front. No blinking at all. If that makes any sense please help. This is hopefully my last hurtle so I can get an inspection sticker
If it's just a bulb I'm going to punch myself . Been looking for bad connections for a few days. Probably should have started with something that simple
This could also be a flasher "on the ragged edge." I would pull ALL of the stop/ signal bulbs, and clean / inspect the sockets and bulbs. See what you have in there for part no's. Then replace the flasher "just because." If you don't do anything else........temporarily swap the hazard and turn signal flashers and see if the problem changes.
