Bulldozer
free ice cream sandwiches
i just swapped out my 6/3 speed manual for a 318/727. the 3 speed has a 2 prong connector from the engine harness to the transmission. of course i had to unplug it . the 727 is a 67 model and i am not using the neutral reverse switch. the first time i went to fire the 318 today , i had no power at the key BUT i was able to jump it at the starter relay with the key on and it started and ran. after shutting it off, i was able to start it with the key a few times with no problem. but now ,once again ,i cant start it with key and i have to jump it at the relay. i have never had a problem before the swap. could it be the connector i unplugged from the 3 speed? can i just jump a wire from one side of the connector to the other?does it matter if i do anything with it? is this related to intermittant power to the key? any idea why i am only getting sporatic power at the key? should i just connect a push button start at the relay? i really need some help here.the car is a 73 duster. thanks in advance!
