Fisher
Old Guy with a Cool car.
Hey guys i need some help here. I am bench testing the NSS sw / BU sw in my 71 duster in the trans on the bench with a continuity tester. There is a full manual valve body in this 727, its a 3 prong sw. I assume that park and neutral are the same location, and just 1-2-3 are now 3-2-1. On the NSS works as it should, on the center pin. I go from center pin to Ground on trans and nothing in park, go to reverse, and i get a beeping, go to neutral and nothing 123 beeping as it should will send a ground up to the sw on the fender.
Back up lights are the outer 2 pins, connect the meter and nothing in park, go to reverse and i get connection, go to neutral nothing, and i get connection between the 2 pins in 1-2-3. Thats not right is it? Is this the wrong sw for the trans, or is something on the new valve body causing the sw to make contact in the forward drive gears? Any body else with a Full manual valve body using th factory wiring for this?
