neutral safety switch
mjs69gts
madison wi
need to confirm if the automatic and manual trans switches are the same as my book does not confirm it thanks
Not even close. Manual trans only has a two pin switch for the reverse light, and used a clutch pedal mounted switch to ground the relay.
Depending on year model, a manual trans build may not have a neutral safety switch at all.
No manual trans Mopar ever had a neutral safety switch. The ones that do have a circuit to ground the relay, all have a Clutch Safety Switch.
Manual trans only ever had a reverse light switch.
