tet68 Well-Known Member Joined Oct 10, 2012 Messages 330 Reaction score 45 Location vicker Jul 10, 2017 #1 on a 67 dart goes from starter relay to transmission is it the same on 69 if I ground it to firewall will car start
krazykuda Well-Known Member FABO Gold Member How-To Section Editor Joined Aug 20, 2007 Messages 66,493 Reaction score 29,747 Location Orland Park, IL Jul 10, 2017 #2 I think the three wire NSS started in 70... (Pun intended....) 67 & 69 should be the single wire...
tet68 Well-Known Member Joined Oct 10, 2012 Messages 330 Reaction score 45 Location vicker Jul 10, 2017 #3 brown wire same place as on 67 but runs into bulkhead connector instead of down to tranny
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,304 Location Idaho Jul 10, 2017 #4 tet68 said: brown wire same place as on 67 but runs into bulkhead connector instead of down to tranny Click to expand... No, the center wire on a 68/ later NSS and the single wire on an earlier goes same place........from one "push on" terminal on the relay, down the top of the trans, to the NSS You are looking at some other wire, possibly the coil bypass
