Relax360
Actually have quite a bit of header ground clearence. The dana was built by Strange has 4.11 gears. Trans is a 727 with Gear Vendors OD on it driveshaft is only 44 inches long so I doubt I will twist it.
Looks almost roomy in there. A 383 might give another 1" on each side. How much weight does the aluminum headers, water pump, and intake save? I would guess 150 lb and put it close to a stock SB.
Looks like front drum brakes, since no booster. I am guessing manual steering is all that clears the headers, and keeps things simple. Not a car a little girl could handle.
Will be nice to see the carb installed and if it clears the hood or you need a hole. That engine and intake is tall.
nice.
you can run disk brakes without a booster, most a body guys dont run power brakes, you can also run power steering with a factory k frame and a big block, i dont see why you couldnt run it with an alterK, and you can fit a BB under a flat hood with no hole if you want too.
i know it uses a RACK.
