danielb927
Hey everyone,
I just bought a new 73 Duster about a month ago. It's in pretty good shape for the 5200 bucks I paid for it, but I do want to get it running a little better and fix up a couple of problems it had or has developed.
First off, I can't start it from inside the car anymore. If I short across the starter relay (which I have replaced) with a screwdriver, with the ignition in ON, it starts and runs. What I had found before was the big wire from positive battery directly to the starter had been worn through by the steering shaft in the engine compartment and was shorting out and grounding directly to the steering shaft. Found it, replaced it, and the thing no longer starts from inside the car. Additionally, a bit later, i noticed the fuel and temp gauges and oil and parking brake lights don't work anymore. The 6 fuse (which I have read goes to the instrument cluster) blows every time I turn the ignition to ON. The battery does not seem to discharge if left connected with the car off.
I really hate electrical work so any help here is much appreciated.
The second thing I'd like to work on is tuning the engine. This is my first muscle car so I don't have much experience except a bit of playing with my friend's 72 'Stang. It's a 360 (I'm told its out of a 75 duster) and was just rebuilt by the previous owner less than a year ago. He dropped in a Comp Cams 280H magnum (280 degrees, 230 degrees at .050, .480 lift and exhaust). It runs fine for cruising, but I can usually smell gas and if i try to really get on it it will stutter once the rpm's get up, almost like it is flooding or something. Carb is a Thermoquad (750 cfm I believe). I haven't yet set the timing except by feel but I'm planning to get a timing light and do that soon, setting to 6-8 degrees BTDC. I've also read I should get a vacuum gauge to set the mixture screws on the front of the carb. Anything else I should be looking at here?
