Slappy
What I have here are Disc brake parts that I bought for a 70 Dart. They will fit other years as well. The calipers and wheel cylinders have a little surface rust on them. All parts are brand new not used. You get calipers, front hoses, rear axle hose, proportioning valve (in-line tube), caliper hardware, steel brake lines and steel line going to rear of car (in-line tube), wheel seals, brake pads ect. 200.00 firm. Parts are located in fredericksburg va 22408. could likely ship in a flat rate usps box maybe two. Ill have to coil up long steel line.
