jeffrey356
I need new linkage and pedal for a carb upgrade. I have a 1965 dodge dart 270 with a 225 c.i. slant 6 with a 1 bbl Holley carb. I'm going to the 2bbl carb and the linkage through the firewall is completely different. Instructions say I will need a 2 to 4 ft cable from the firewall. I'll probably have to replace pedal and linkage through a new hole in the firewall. The existing linkage is completely funky and actually rotates the linkage to the 1 bbl holley. I'll need a set-up that pushes directly forward to attach to the 2bbl. I'm pretty sure some cutting and drilling will be needed for the upgrade. jeffrey356.
