Working on cleaning up the wiring in the engine bay. I wanted to run the alternator wiring direct to starter relay with a circuit breaker with reset, bypass the amp meter, clean up connections there and run wiring to some sort of fusable distributon block. i also have a small underdash amp that needed direct power. I also purchased the headlight wiring and relay kit from rob (crackedback) to help out the headlights. After discussions with Rob, I decided I would draw up some kind of diagram for other member to see and chime in. Any comments are welcomed but please not ...I am not a electrical expert and used a program to the best of my abilities to try and draw this up for you guys to see.
