You MIGHT have "blowed up" the big splice in the black ammeter wire up under the dash. This is a splice a few inches from the ammeter all taped up in the under-dash harness, so you'll have to pull the cluster and cut / untape the harness from the black ammeter terminal down into the harness a few inches.
I would check first at the headlight switch. That splice feeds off to
the ignition switch
the hot buss in the fuse panel
and direct to the headlight switch
Another easy place to check is at the dimmer switch. Should be power on any two of the switch pins with the light switch on.
And before you tear into the dash, remove the bulkhead connector sections and inspect them for damage.
Read this...........even if you don't do this modification. It gives you a very good overview, and "how it works:"
http://www.madelectrical.com/electrical-tech.shtml
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
This simplified diagram from the page above shows the primary power distro
Also if you don't have one, download a free factory service manual from Mymopar
http://www.mymopar.com/index.php?pid=31
Sometimes easier to follow, but not always correct, are somewhat simplified aftermarket wiring diagrams from the same site:
http://www.mymopar.com/downloads/1967/67CoronetA.JPG
http://www.mymopar.com/downloads/1967/67CoronetB.JPG
This is a "full set" of diagrams out of the service manual
mymopar.com/downloads/1967/67_Dart_Charger_Wiring_Full.pdf
