Does not
That would lead me to believe there's some kind of master cylinder problem going on
Does not
We are on the same page.If you hold the pedal down, it will sink over time if you have a bad master cylinder.
I would block the pedal down overnight and then re-bleed in the morning. Usually if you hold pressure for a long period, it will work the air out.
I'm not sure... Cass sent me a new master cylinder. Although better, it's still not great. My car isn't driving yet though. So I'm not really sure. It'd be nice to drive it and rebleed after it's had some heat and drive time on em.Did you ever solve this? I’m having the same issue with a similar setup
Thanks,
Keith
You have 4 wheel disc brakes and a 15/16" master cyl, although it gives you more stopping power it takes more travel to move all the pistons. I think you would be better off with the 1 1/32" master cyl as it will move more fluid and not travel as far. Power booster would help a lot, the ratio is different and you can use a bigger master cyl.
Cass from Dr Diff sent me this link trying to help me get my pedal to feel right. It made a lot of sense and I just knew it would fix the issue but nothing changed. Maybe it’ll help some of you.If the rear calipers are equiped with an internal emergency brake (screw) behind the Piston, the emergency lever may need to be activated several times to get the pads/pistons into contact with the disc.
I think my new master may be defective.
A 15/16 master has higher line pressure. Should result in less pedal effort and greater feel.
Well ****, you might be on to something there! My ebrake isn't hooked up, so that hadn't even crossed my mind. I'll have to give it a go.Yep, that's the one,
You won't get a hard pedal till you adjust the emergency brake.
Thanx Craig.
Try bleeding with the emergency adjusted AND applied.
Cheers
72bluNblu what do you disagree with?
Everything in your statement. The 15/16” master should work fine. The 1-1/32” isn’t a better choice in my opinion (I’ve run both). The long travel in this case isn’t an issue with the master cylinder diameter.
And the power booster comment is wrong. Yes, there is a linkage difference, but it doesn’t work the way you think it does. The factory ran 15/16” masters with the power booster and 1-1/32” masters with manual brakes.
That is what I said, the smaller master with power brakes because the ratio is different and the master moves further and the pedal less than with manual brakes, that's why you need a bigger diam master with manual brakes to fill the 10 caliper pistons with fluid, and if you add a booster it wont take very much pedal effort at all to stop the car. But like I said it is a lot of brake for a light car so he shouldn't have a problem.
