new car on the jig
mprdrgrcr
Thought i would post some start up pics of my new Super Gas 68 Cuda.
I don't have any idea how to do this kinda work, LOL. massive.
Nice! I can tell from the jig it's not your first rodeo :). That 572's numbers should easily give you some flexibility on the stop. Have fun with the build & keep us informed with the progress. Member since 2008...Don't be a stranger. :D
Thanks for the compliments. Nope not my first build but this is the first for myself in a long time. Thought you would enjoy. Added a few more bars over the weekend. Just a few more to go and I can get the body out of the way to finish all the small stuff on the chassis before re-attaching and starting the sheet metal work. The body will get new quarters and rockers, basically just using the roof from the original car. Shooting for 2400# with me in the seat. In theory with the power the engine makes it should run 7.9 @ 170 off the stop. In reality it will probably run 8.20-8.30's.
Yea...:happy1: on my second bag.
This thing already looks fast!
with that much h.p., it had better be lite, we broke 8 3/4 rears every other week-end till we went w/ a dana 60. car was heavier tho just sayin
I do believe the 9" is up to the task.
Very nice work. If your attention to detail follows through the whole job , this one is gonna be purdy !:D:D
Nice, I was wondering why you didn't make it a double rail to motor plate, aka, Pro mod/ Pro stock style. The small stuff will take all the time as you know. Where are you located?
Keep the pics coming!
I'm in Suffolk Va. There are a couple reasons for not using the double frame rail design. I feel they are for cars with a lot more hp, 1500+. They are hard to work aroung inside the car. The transmission in this type of chassis has to be removed from inside the car and handed out the passenger door. I "super class" racing the transmission and converter see more action than anything else and need to be easy to r and r. Then there is the weight issue. I know there are a lot of bars in there but I am trying to keep them to a minimun compared to current chassis out there.
yes, ive pulled many jericos and lencos out of the cavity. that 400 ain't light either
Trimmed a few unnecessary things off the body in prepartation to mount the front suspension. Did quick trial fit of the front end to make sure the wheel/tire will end up where it is supposed to and the proceeded to mount the struts, radiator, trans cooler and prep for motor plate.
On to the detail work now. Motor plate, control arm mounts, master cylinder, line loc, brake and gas pedals, shifter mount and driveshaft loop......
